SanDiegoCBR750
Dec 07, 2021Aspirant
CBR750 not working with BIG-IP VPN software
I have a new Orbi CBR750 (AX4200) with one satellite. The connectivity is excellent from both the main router and the satellite. Unfortunately when I connect to my work VPN (BIG-IP Edge Client) the...
Dec 08, 2021Guru - Experienced User
Are you using a wired or wireless connection to the CBR?
Does a different brand of VPN experience the same thing to compare?
- SanDiegoCBR750Dec 08, 2021Aspirant
Thank you for your help. Here are the answers to your questions:
1. I am connecting to the Orbi RBR and RBS over WiFi (not using a wired connection)
2. Firmware relieases:
CBR750 router firmware version: v4.6.5.8
Orbi satellite firmware version: v4.6.5.14
3. My wife is experiencing the same connectivity problems when she connects over her company's VPN. She is travelling so I do not have her VPN software name.
Again, thanks
- FURRYe38Dec 09, 2021Guru - Experienced User
I wonder if you use the CBRs DMZ for your PC, if this changes the behavior.
No running out of ideas. Possible FW is not handling the VPN correctly or maybe some compatibility issue.I would make contact with NG support and let them know what your seeing.
