Heyrip
Dec 20, 2022Guide
CBR750 now not working with Xfinity
I have CBR750 with one satellite, Xfinity is the ISP. Worked great for more than a year until Xfinity "upgraded" their system in my area (Bellevue, WA) early November, then several times I had to un...
Dec 21, 2022Guru - Experienced User
If the CBR had been working then he ISP had problems in your area then the CBR stopped working, this would fall on the ISP to correct this.
The CBR would need to be hook up and would need the following posted here:
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Are there any transmission issues reported by the ISP that they might report the CBR as being off line by chance?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
