Heyrip
Dec 20, 2022Guide
CBR750 now not working with Xfinity
I have CBR750 with one satellite, Xfinity is the ISP. Worked great for more than a year until Xfinity "upgraded" their system in my area (Bellevue, WA) early November, then several times I had to un...
Blanca_O
Dec 21, 2022NETGEAR Employee Retired
Hi Heyrip,
We are looking into the issue. Kindly send me a private message with the device serial number and MAC address.
Blanca
Community Team
- HeyripDec 21, 2022Guide
Blanca, thanks for the reply. How do I send a private message to you?
- FURRYe38Dec 21, 2022Guru - Experienced User
Select on her user name.
- HeyripDec 22, 2022Guide
Thank you for your suggestions. I was successful in sending a private message to Blanca. Your first message was beyond my pay grade 😜 and I am not even at the problem location...I'm renting the place out and trying to solve the problem at a distance. And now the CBR750 is not even connected--I'm having to temporarily rent a cable modem/router from Xfinity until this problem is solved. Thanks again for your suggestions!
- night64Dec 23, 2022Aspirant
Having same issue from where I have to send message privately tell us here please .
- FURRYe38Dec 23, 2022Guru - Experienced User
Kindly send Blanca_O a private message with the device serial number and MAC address.
FW version your using on the CBR as well.
- FURRYe38Dec 24, 2022Guru - Experienced User
Unless there making changes to there services, the CBR does support 1Gb connections with ISPs. It can actually support well beyond 1Gb if you had 4 LAN ports all streaming at 900Mpbs all at once to saturate the connection over the coax line.
Someone at XF is lying to you.
cshep5528 wrote:
So after 2 hours on the phone with Xfinity they told me that the orbi 750 doesn't work with 1gb internet. I downgraded to 800 mbps. Now I am stuck paying $30 more per month for slower internet. I hate comcast.
