Heyrip
Dec 20, 2022Guide
CBR750 now not working with Xfinity
I have CBR750 with one satellite, Xfinity is the ISP. Worked great for more than a year until Xfinity "upgraded" their system in my area (Bellevue, WA) early November, then several times I had to un...
Heyrip
Dec 21, 2022Guide
Blanca, thanks for the reply. How do I send a private message to you?
Dec 21, 2022Guru - Experienced User
Select on her user name.
- HeyripDec 22, 2022Guide
Thank you for your suggestions. I was successful in sending a private message to Blanca. Your first message was beyond my pay grade đ and I am not even at the problem location...I'm renting the place out and trying to solve the problem at a distance. And now the CBR750 is not even connected--I'm having to temporarily rent a cable modem/router from Xfinity until this problem is solved. Thanks again for your suggestions!
- FURRYe38Dec 22, 2022Guru - Experienced User
Hopefullly the ISP and NG can get this solved soon.
