mattr_06
Jun 25, 2023Follower
CBR750 now not working with Xfinity
I'm currently facing persistent internet connection issues with my ORBI CBR750 router, and I'm seeking some guidance or advice from the Netgear community. To provide some context, I find myself h...
Jun 26, 2023Guru - Experienced User
What Speed Tier package do you pay for UP and Down from the ISP?
Also power is a bit on the high side:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Might ask the ISP to lower the power a bit.
Any Criticials, Errors or Warnings seen in the Event log should be reviewed and resolved by the ISP.
