ArekB's avatar
ArekB
CBR750 problem with connection and setup
Few things happened
STEP1: I had problems with internet over last 2 weeks. People during calls will complaint that i drop out. Xfinity came to check and replaced the cable but problem continues.
STEP2: I decided to do factory reset on my CBR750 and both satelites. After the restart i cannot setup it with mobile app. When i connect to wifi it is showing connected but no internet access (despite the fact that all 4 diodes are up).
STEP 3: I connected cable connection and i was able to get internet on my laptop. I setup modem/router via web interface but & selected same wifi/password. Ultimately my mobile phone is showing that it cannot connect to wifi (connection failed)
STEP4: factory reset again, cable connection to laptop, setup new wifi name & password -> at this moment my mobile can connect and access internet
STEP5: i don't want to change wifi setting for all 50 devices which i have at home.  So i setup guest network with old login and password and some devices can connect while some others cannot (like my Samsung S22 phone or Roku TV)
It seems that factory reset is not really fully cleaning the modem...I manually updated firmware (same was installed before restart) and tried above steps multiple times. All the time same results...Any idea how to really fully clean CBR750? or what else to do to make sure it is working correctly?
thanks
  • FURRYe38's avatar
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    • ArekB's avatar
      ArekB
      i am trying to reply but seems my replies get deleted 😞
      i have 2 satellites but i didn't set them up till now. I cannot even setup main modem, not talking about satellites
      i have 3500sq ft + basement, each floor has 1 orbi, aroun 20-30ft from each other
      Wired seems to be working fine, wireless seems to be a problem
      i am using auto channel for 2.4ghz and 48 channel for 5ghz
      it is single family house, not sure if neighbours have netgear
      i am thinking to maybe do factory reset through web menu, not sure if it makes any difference
      connection is good now, below are the logs
      Cable Diagnostic
      Status: Good
      Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
      Internet Access: Good
      Downstream Status: Good
      Downstream Power Level: Good
      Downstream SNR: Good
      Upstream Status: Good
      Upstream Power Level: Good
      Current time: Mon Dec 11 18:48:58 2023
      Startup Procedure
      Acquire Downstream Channel: 549000000 Hz Locked
      Connectivity State: Ok Operational
      Boot State: Ok Operational
      Security: Enabled BPI+
      IP Provisioning Mode: Honor MDD honorMdd(4)
      Downstream Bonded Channels
      Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
      1 Locked QAM 256 42 447000000 Hz 7.5 38.6 0 0
      2 Locked QAM 256 43 453000000 Hz 7.9 38.9 0 0
      3 Locked QAM 256 44 459000000 Hz 7.5 38.9 0 0
      4 Locked QAM 256 45 465000000 Hz 7.5 38.9 0 0
      5 Locked QAM 256 38 471000000 Hz 7.8 38.9 0 0
      6 Locked QAM 256 39 477000000 Hz 8.0 38.9 0 0
      7 Locked QAM 256 40 483000000 Hz 8.0 38.6 0 0
      8 Locked QAM 256 41 489000000 Hz 8.0 38.9 0 0
      9 Locked QAM 256 32 495000000 Hz 8.3 38.9 5 0
      10 Locked QAM 256 34 507000000 Hz 8.3 38.9 0 0
      11 Locked QAM 256 35 513000000 Hz 8.3 38.9 0 0
      12 Locked QAM 256 36 519000000 Hz 8.4 38.9 2 0
      13 Locked QAM 256 1 525000000 Hz 8.4 38.6 0 0
      14 Locked QAM 256 2 531000000 Hz 8.5 38.9 0 0
      15 Locked QAM 256 3 537000000 Hz 8.5 38.6 0 0
      16 Locked QAM 256 4 543000000 Hz 8.5 38.9 0 0
      17 Locked QAM 256 5 549000000 Hz 8.6 38.9 0 0
      18 Locked QAM 256 6 555000000 Hz 8.8 38.9 0 0
      19 Locked QAM 256 7 561000000 Hz 8.8 38.6 0 0
      20 Locked QAM 256 8 567000000 Hz 8.5 38.6 0 0
      21 Locked QAM 256 9 573000000 Hz 8.9 38.6 0 0
      22 Locked QAM 256 10 579000000 Hz 8.9 38.9 0 0
      23 Locked QAM 256 11 585000000 Hz 8.9 38.6 0 0
      24 Locked QAM 256 12 591000000 Hz 9.0 38.9 0 0
      25 Locked QAM 256 13 597000000 Hz 9.0 38.9 0 0
      26 Locked QAM 256 14 603000000 Hz 9.0 38.6 0 0
      27 Locked QAM 256 15 609000000 Hz 9.1 38.6 0 0
      28 Locked QAM 256 16 615000000 Hz 9.1 38.6 0 0
      29 Locked QAM 256 17 621000000 Hz 9.3 38.9 0 0
      30 Locked QAM 256 18 627000000 Hz 9.4 38.6 0 0
      31 Locked QAM 256 19 633000000 Hz 9.4 38.6 0 0
      32 Not Locked N/A 0 0 Hz 0.0 0.0 0 0
      Upstream Bonded Channels
      Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
      1 Locked ATDMA 4 5120 16400000 Hz 43.3
      2 Locked ATDMA 3 5120 22800000 Hz 43.0
      3 Locked ATDMA 2 5120 29200000 Hz 42.8
      4 Locked ATDMA 1 5120 35600000 Hz 43.3
      5 Locked ATDMA 10 2560 40400000 Hz 40.3
      6 Not Locked N/A 0 0 0 Hz 0.0
      7 Not Locked N/A 0 0 0 Hz 0.0
      8 Not Locked N/A 0 0 0 Hz 0.0
      Downstream OFDM Channels
      Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
      1 Locked 3 37 762000000 Hz 11.5 dBmV 39.4 dB 1108~2987 0 0 0
      2 Not Locked 0 0 0 Hz 0.0 dBmV 0.0 dB 0~4095 0 0 0
      Upstream OFDMA Channels
      1 Not Locked 0 0 0 Hz 0.0 dBmV
      Event Log
      Time Priority Description
      Dec 31 1969 18:01:02 Error Missing Mandatory MDD TLV on primary DS Channel
      Dec 31 1969 18:01:25 Critical No Ranging Response received - T3 time-out
      Dec 11 2023 17:01:30 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
      Dec 11 2023 17:01:30 Notice TLV-11 - unrecognized OID
      Dec 31 1969 18:01:02 Critical No Ranging Response received - T3 time-out
      Dec 31 1969 18:01:05 Warning RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
      Dec 11 2023 17:43:48 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
      Dec 11 2023 17:43:48 Notice TLV-11 - unrecognized OID
      Dec 11 2023 17:44:22 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
      Dec 11 2023 17:44:22 Warning TCS Partial Service
      Dec 31 1969 18:01:04 Critical No Ranging Response received - T3 time-out
      Dec 31 1969 18:01:08 Warning RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
      Dec 11 2023 17:57:44 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
      Dec 11 2023 17:57:44 Notice TLV-11 - unrecognized OID
      Dec 31 1969 18:01:01 Critical No Ranging Response received - T3 time-out
      Dec 31 1969 18:01:09 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
      Dec 11 2023 18:26:52 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
      Dec 11 2023 18:26:52 Notice TLV-11 - unrecognized OID
