ArekB
Dec 11, 2023Aspirant
CBR750 problem with connection and setup
Few things happened STEP1: I had problems with internet over last 2 weeks. People during calls will complaint that i drop out. Xfinity came to check and replaced the cable but problem continues. ST...
Dec 12, 2023Guru - Experienced User
I presume you have contacted the ISP to have them associate the CBR with there services right?
That has to be done first.
Is the the main issue your having?
Still need to take to the ISP about the power levels.
Should be able to use a wired PC and web browser to set up the CBR unit at 192.168.1.1.
ArekB
Dec 12, 2023Aspirant
yes
i have activated the modem with Xfnity.
Xfinity technician visited, they replaced entire cable and said everything is good at their side.
Ultimately problem seems to be with ORBI. When i connect with my mobile it is shwoing no internet conenection while with cable connection internet is working. It also seems that it is not full factory reset as it is still somehow not working when i try to reuse previous wifi name. if i setup new wifi network it seems to work better (after cable setup)
