ArekB
Dec 11, 2023Aspirant
CBR750 problem with connection and setup
Few things happened STEP1: I had problems with internet over last 2 weeks. People during calls will complaint that i drop out. Xfinity came to check and replaced the cable but problem continues. ST...
ArekB
Dec 16, 2023Aspirant
Iwas testing and resetting over last days. I was able to setup orbi using mobile app with temporary network name and password. I think problem is that if I try from the beginning using my original network name all 50devices are trying to connect to orbi during setup and orbi is blocking that. After everything was setup with temp network I changed network name to my original "AB-wifi" and almost everything works fine.
I still have my original problem that people are complaining that I am dropping out during team calls, I hear them well all the time. I put one of satellites next to my laptop and using cable connection it works well. Any idea what might be going wrong with wifi connection? Or at least how to test it without waiting for people to complain they cannot hear me? This problem started 3 weeks ago and was working perfectly during previous year. Thank you
Dec 18, 2023Guru - Experienced User
Is SIP ALG option enabled or disabled on the RBR? Under Advanced Tab/Setup/WAN Setup.
- ArekBDec 18, 2023Aspirant
NAT filetering is secured
Disable SIP APG is selected
not sure what is it doing?
- FURRYe38Dec 18, 2023Guru - Experienced User
Might give enabling SIP ALG a try and see if this changes anything for the teams meetings.
I don't think NAT Filter will change anything however you can try it. Put it back if you don't notice any changes.
