Bjhickman1956
Dec 20, 2021Tutor
CBR750 router intermittent connection with Dell desktop
I purchased an Orbi mesh WI-FI 6 router/modem combo with one satellite in early December (2021). I successfully installed it a couple of days ago, and all wireless devices were interfacing properly (i...
- Dec 22, 2021Problem solved! (Inadvertent) operator error. Somehow I fat fingered the internet “pause” icon on the Orbi app which prohibited several devices from seeing the internet. Had nothing to do with the printer - just happened in the same timeframe as the printer install.
Anyway, thanks for all your replies.
Bjhickman1956
Dec 22, 2021Tutor
The desktop is connected to the printer via WI-FI (in an attempt to keep cable clutter to a minimum). I did call Netgear because I actually purchased the extended support (I’m that bad at IT). But OMG, I was dismayed at the incredibly thick Indian accents! The person that answered the call tried to repeat my email address back to me probably 5 times, and I could never tell if she got it right. I did eventually get transferred to someone I could understand better, but his only suggestion was to reboot the router - which I had done multiple times. Not a great experience. So I have Geek Squad coming now. Turns out my Ring doorbell quit working the same day that I installed the printer, so I’m thinking devices are fighting over addresses of some kind. Way beyond my pay grade, but hopefully it’ll get resolved soon. Thanks for your answer.
CrimpOn
Dec 22, 2021Guru - Experienced User
Sorry I was unclear. The desktop is connected to the Orbi WiFi system with ethernet cable or WiFi?
Most user connect every device to the WiFi router and use the router to communicate between themselves.
For example, I have one printer that is connected to the Orbi with an ethernet cable (because I had a port open) and every device in the house (desktops, laptops, phones, tablets) prints to it by going through the Orbi router.
Are you able to access the Orbi system using the web interface (http://orbilogin.net) or the Orbi 'app'?
Would be useful to jot down the IP addresses that have been assigned to all of your devices, including the new printer.
