AGLang
Sep 13, 2022Aspirant
CBR750 slow network and disconnects
Purchased a CBR750 with 1 satellite a little less than 6 months ago, and I have had nothing but issues with it. Bad connectivity to the internet, constantly having to reboot it. Recently moved t...
AGLang
What channels are you using?
(2.4GHz) Auto and (5GHz) 48Auto?
I see 6 other SSID's
Do you have a RBS deployed as well or only the CBR?
1 RBS. The area we live in is very small, 2 bedroom apartment on the floor
Sep 13, 2022Guru - Experienced User
Ok. What is the sq feet of this place?
Possible having too much signal in a small place will cause problems. Lets turn OFF The RBS for now and see how it goes.
I would also reduce the transmit power on the CBR from 100% to 50% as well. Under Advanced Tab/Advanced Settings/Wireless Settings
- AGLangSep 13, 2022Aspirant
~1000 sq ft
already reduced transmit power to 50% on 2.4GHz and 5GHz. did not solve the issue.
