Taylorinnyc
Sep 28, 2021Guide
Cbr750 speed issue with comcast
Thanks in advance for all help. I replaced my xfinity modem/router with the cbr750 modem/router and satellite. After installing my speeds were in my normal range of 1000-1400 mbps. Two days ago the s...
- Oct 05, 2021I’m sorry, got so crazy with all of this and never updated what happened. On my last call with the orbi support guys, he finally said to me that the orbi system may not be best for my setup and the size of my house. He recommended I return it and buy a cm2000 modem and a rax200 router. I took apart the orbi system and returned it, the nighthawk stuff arrived the next day and I installed everything. So far I have great speeds and signal throughout the house. I was surprised that he said the orbi wasn’t right for me but so far the nighthawk system seems great. I really appreciate all your help, so sorry I didn’t update. I just got so frustrated that it slipped my mind. Thank you!
Taylorinnyc
Sep 29, 2021Guide
So an update on my issue, i got an ethernet adapter for my macbook so i could test the speed directly from my router. Its constantly about 910-925. So is the issue the wifi signal? for some reson no device can get over 650 mbps over wifi. i assume this means my xfinity connection is good?
Sep 29, 2021Guru - Experienced User
What wifi devices are you speed testing with?
Some have been complaining about recent FW having problem with speeds recently.
Yes, the ISP service is good.
- TaylorinnycSep 29, 2021GuideI have used iPhone, iPad, MacBook Pro. I had tested the speed with a wired connection on my ps5 which was only about 300. Unfortunately I don’t have anything non Mac to test the WiFi with now that I think about it.
- TaylorinnycSep 29, 2021GuideI’m going to test the speed on the ps5 through WiFi without the Ethernet.
- TaylorinnycSep 29, 2021GuideThe ps5 through WiFi only getting 100 mbps. I don’t get it.
- FURRYe38Oct 05, 2021Guru - Experienced User
Any progress on this?
- TaylorinnycOct 05, 2021GuideI’m sorry, got so crazy with all of this and never updated what happened. On my last call with the orbi support guys, he finally said to me that the orbi system may not be best for my setup and the size of my house. He recommended I return it and buy a cm2000 modem and a rax200 router. I took apart the orbi system and returned it, the nighthawk stuff arrived the next day and I installed everything. So far I have great speeds and signal throughout the house. I was surprised that he said the orbi wasn’t right for me but so far the nighthawk system seems great. I really appreciate all your help, so sorry I didn’t update. I just got so frustrated that it slipped my mind. Thank you!
- atejwaniOct 05, 2021Apprentice
Thanks, Taylorinnyc, for your update. I too am surprised by Netgear Support team recommending different hardware!
I also have Xfinity/Comcast as my ISP providing 1.2gb down/40mb up service in the San Francisco Bay Area. I've had the Netgear Orbi CBK752 (CBR750 & RBR750) since Nov 2020, and all worked well till the middle of September 2021 when the firmware upgrades degraded performance and stability.
Netgear Support Team - Blanca_O , DarrenM - Is this even an option for me to return CBK752, and get credit towards procuring CM2000 and RAX200, after 11 months of use?
cc: FURRYe38
Thanks in advance,
Al
Taylorinnyc wrote:
I’m sorry, got so crazy with all of this and never updated what happened. On my last call with the orbi support guys, he finally said to me that the orbi system may not be best for my setup and the size of my house. He recommended I return it and buy a cm2000 modem and a rax200 router. I took apart the orbi system and returned it, the nighthawk stuff arrived the next day and I installed everything. So far I have great speeds and signal throughout the house. I was surprised that he said the orbi wasn’t right for me but so far the nighthawk system seems great. I really appreciate all your help, so sorry I didn’t update. I just got so frustrated that it slipped my mind. Thank you! - TaylorinnycOct 05, 2021GuideAfter a lot of reading, I believe that a firmware update somewhere along the line is the problem I was having. I had exactly the same speeds you described from xfinity. When the orbi was first installed I had the same speeds, once it updated there was no going back and they didn’t seem to believe that was the issue. I’m glad I made the change at this point. So sorry for the troubles.
Thanks for letting us know.
Enjoy. - stjames70Nov 04, 2021GuideLatest firmware finally fixed issue with Comcast — see posted photo — 1.4 Mbps service from 1.2 Mbps Comcast service — amazing. I could only get 900Mbps before.
- FURRYe38Nov 04, 2021Guru - Experienced User
NICE. Thanks for letting us know.
Enjoy.
