PatronBlair
Oct 29, 2021Aspirant
CBR750 Stop Working Today
My CBR750 Stop Working this morning, Power REBOOTED 6 Times, Did it again from the Web orbiLogin 2 times, and Called Spectrum, and they could see the Orbi, but it would not connect. Everyone els...
Oct 29, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi With Cable Modem products. Most of the people who watch that forum are more likely to have experience with Orbi with cable modem and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
- PatronBlairOct 29, 2021Aspirant
Thank You! But the unit started working all by it self - I DON'T TRUST Spectrum
- FURRYe38Oct 29, 2021Guru - Experienced User
Anything can happen at the ISP level.
Make a new post over in the Orbi with cable modem forum if you feel you need to get more information.
Have the ISP check there signal on the line to up to the modem. It's there responsibility.
- FURRYe38Nov 02, 2021Guru - Experienced User
