IDDQD123
Dec 21, 2021Aspirant
CBR750 Wireless devices connect, but no internet
Thanks for looking at this. It has been bewildering to say the least. I have a CBR750 + 1 satellite. Until today, everything was fine (using Coax with Spectrum) no issues with a single device, b...
CrimpOn
Dec 21, 2021Guru - Experienced User
(You are not going to like this....)
The CBR750 is a combination cable modem/router/WiFi device.
https://www.netgear.com/images/datasheet/orbi/CBR750.pdf
It is intended to take the place of an ISP cable modem and connect to the coax cable from the ISP. It is not intended to connect to a different type of internet service (such as an AT&T router). Notice that there is no ethernet port on the back labelled "WAN" or "Internet". Notice how the installation guide describes connecting the coax cable and says nothing about connecting an ethernet cable.
https://www.downloads.netgear.com/files/GDC/CBR750/CBR750_QSG_EN.pdf
The User Manual on page 62 describes the two 'modes' for this device:(a) Router and Access Point and (b) Bridge Mode, where it is essentially a replacement for the ISP modem that has no additional functions.
My sense is that you need to (a) go back to Spectrum, or (b) get a different WiFi system.
Sorry.
- IDDQD123Dec 21, 2021Aspirant
While I somewhat understand the sentiment, I do feel like we're pivoting from the question posed. If the network as connected was altogether non-functional, I'd just pack my things and go home.
However, Orbi does/did function as a router for about 80% of the connected devices without issue, so I'm more focused on what the problem with the other 20% not sending/receiving traffic is, rather than how to replace the whole system. I understand there isn't a manufacturer manual for this, which is why I'm hoping to find some community knowledge here.
I'd suggest a parallel: a manufacturer won't suggest the best way to place a towel under a door to stop the heat from escaping, but if all I have is towels and I put them under 4 doors and it worked perfectly, but the heat is still leaking from the 5th door, I'm not looking to go buy 5 new doors, but to figure out what's keeping the 5th towel from stopping the heat escaping. If it worked 0/5, I wouldn't bother asking for advice.
I get that throwing money at the problem is *a* solution, but if there are a couple of software tweaks (opening ports, checking device permissions, changing DNS server are some I've considered), that would be *the* solution I'm looking for.
PS: I did swap my R7000 Nighthawk for now, to handle the rest of the devices in the half of the house AT&T router can't reach, but it's clumsy with dead spots and buying a $400+ replacement doesn't excite me. I'd rather try my luck with a different manufacturer if that's the route I'll have to go.
Cheers and Merry Christmas!
- CrimpOnDec 22, 2021Guru - Experienced User
The user manual is here: https://www.downloads.netgear.com/files/GDC/CBK752/CBK750_UM_EN.pdf
This does appear to be a unique opportunity to learn more about combination cable modem/routers.
- On the Orbi case, what do the LED's show? (see manual page 10. Particularly the Internet LED)
- On the Orbi web interface, what does it show in the Internet Menu (or the Internet section of the Advanced Tab home page) for the Internet IP address, subnet mask, and gateway?
(With non-cable modem routers, the AT&T BGW320 will supply a private IP address to the Orbi, such as 192.168.1.?)
Orbi routers can function without an internet connection, so local connections such as media servers should function.
- IDDQD123Dec 22, 2021Aspirant
I was referencing that there isn't a manual for setting this Modem Router as Router only (the only option in advanced was whether to use it as a Router - yes by default, and I learned that by disabling it, it acts as modem only and to be accessed again has to be factory reset).
Power and Internet LED's were solid, downstream was blinking white (at least when I looked at it), upstream was off. Probably kept trying to check if there's any data to move on Coax, but there wasn't one plugged in.
Ring LED was amber. The subnet IP was something like 192.168.1.19, gateway showed the subnet IP for the AT&T router. I can't recall the subnet mask.
Seems like it was working as a switch with ethernet connetions. AT&T router saw all WiFi devices (even ones that didn't get internet data) as ethernet connections on its end, but they showed up properly in Orbi's device list as whether wireless or wired.
