zerolab
May 08, 2021Guide
CBR750 with RBW30 satellites
I am looking to upgrade my system but don't want to do all at the same time. Does the CBR750 work with previous generation satellites?
zerolab
May 08, 2021Guide
Are there wall plug equivalent for the CBR70
May 08, 2021Guru - Experienced User
You can connect EX/EAX series wifi extenders to Orbi AX systems. My EX7500 works with my Orbi AX system. NG doesn't make it known for future product releases. Only when they announce something will it be known at that time.
