mirage_man
Sep 29, 2020Guide
Chamberlain MYQ Orbi752 won't connect
Recently upgraded to a new mesh Orbi 752 system and all is working well except I can't get it to connect with my Chamberlin garage door opener MYQ. I know this is an issue resulting from the fact that...
- Oct 22, 2020Wouldn't you know it but Chamberlain support had a fix!
Apparently the issue was using the Android app to try to connect. They showed me a work-around using a web interface to authenticate the network.
Here's what I did..
#1) Go through steps to update wifi settings via control panel on opener itself. (push and hold rectangular button until led button lights turn off on unit. Then push yellow round button 3 times. Rectangular button will blink blue.)
#2) Go to wifi settings in phone and myq opener should be visible. Select it. Let it connect.
#3) Open a browser on phone. Type in "setup.myqdevice.com" and enter. It will open a web interface for setting up the wifi. Follow prompts and it should work. It did for me and I was even able to leave AX mode enabled as well as go back to regular wpa2.
mirage_man
Oct 22, 2020Guide
Would not connect in WPA+TKIP
Oct 22, 2020Guru - Experienced User
I would discuss this with the mfr of this device first then NG support. Seems like there is a security mode incompatibilty issue between the Orbi and this device.
- mirage_manOct 22, 2020GuideI know where this goes. The two manufacturers pointing their fingers at each other. Ugh
I already spoke with NG support. Read first post for their recommendations. - mirage_manOct 22, 2020GuideCan anyone offer help as to how to add my old asus router to this network so I can use it to connect to the myq?
- mirage_manOct 22, 2020GuideWouldn't you know it but Chamberlain support had a fix!
Here's what I did..
#3) Open a browser on phone. Type in "setup.myqdevice.com" and enter. It will open a web interface for setting up the wifi. Follow prompts and it should work. It did for me and I was even able to leave AX mode enabled as well as go back to regular wpa2. - FURRYe38Oct 22, 2020Guru - Experienced User
Awesome, thank you for posting that. Hope it helps other users for this device.
Enjoy. :smileywink:
- Mikey94025Oct 22, 2020Hero
Apparently the issue was using the Android app to try to connect. They showed me a work-around using a web interface to authenticate the network.Yes, this is the method where the device tells you what SSIDs it sees and you pick from them. It's only when using the app that the device gets confused because the phone supports different wireless protocols than the device. This technique should also work for 2.4Ghz devices whose apps get confused by phones connected via 5Ghz.
