JYurt's avatar
JYurt
Tutor
Jan 16, 2021
Chamberlin - MyQ tried everything RBK50
Frustrated...just spent a bit moving from my NIGHHAWK to the 'mesh' thing.   i have tried everything SHORT of RECONNECTING my old router and or extender after spending time (so as you all dont was...
  • JYurt's avatar
    Jan 16, 2021
    solved my problem..yea me...
    had to reconnect  / reconfigure the OLD extender to get the garage to MYQ to recennect.
    then sfter connecting i reconfigured MYQ to see the ORBI network, which it did, and connected to the 2.4Ghz side of the ORBI
    removed the extender
    all is fine...
