hya_it
Apr 27, 2023Aspirant
Change IP Guest Wifi
Hello, I want to change the IP range of my guest Wifi, since 192.168.2.1, which is the default one, is a LAN that I am already using and I have the problem that it has LAN access when it should not ...
Apr 27, 2023Guru - Experienced User
Why not just switch the other device off the 2.1 subnet? Might be easier.
