hya_it
Apr 27, 2023Aspirant
Change IP Guest Wifi
Hello, I want to change the IP range of my guest Wifi, since 192.168.2.1, which is the default one, is a LAN that I am already using and I have the problem that it has LAN access when it should not ...
Apr 27, 2023Guru - Experienced User
I don't believe GN is configurable on its IP address range since the intent of the GN is for limited and temporary use by devices that only need internet access for a short period of time.
