miketheknight20
May 16, 2023Apprentice
Change IP/SUBNET
I have the netgear orbi rbr750 - my current IP/submet is 192.168.5.XXX Set-up is up and running, but I need to change that to be a 172.16.5.XX How do I go about changing this?
miketheknight20
And will the starting & ending IP auto-update based off the change I make to the IP Address?
May 16, 2023Guru - Experienced User
Yes. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: .#.100 to .#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- miketheknight20May 16, 2023Apprentice
Probably a stupid question but would rather ask...process is the same for the orbi and the nighthawk?
