MickeyKelly
Sep 06, 2022Aspirant
Change topology from star to daisy chain Orbi 753
All of my Google searches say to go to the Advanced tab, Wireless, Advanced and change the setting. This option doesn't exist there. Can someone point me in the right direction?
- Sep 06, 2022
You used to be able to change it on the AC versions but the AX versions don't have the option. I
Sep 06, 2022Guru - Experienced User
- MickeyKellySep 06, 2022Aspirant
Thank you.
