scimini
Apr 13, 2021Guide
Changed SSID name, no longer can access Orbi control panel
Recently upgraded to the RBK752. In an effort save time, I renamed my ssid to the name of my old router so I didn't have to update every device. Once I changed the name, I can no longer access t...
- Apr 13, 2021
You may need to factory reset the RBR and setup from scratch with a wired PC and web browser...
Apr 13, 2021Guru - Experienced User
What version of FW are you using?
Try a power OFF of the RBR and RBS for 30 seconds then back on?
Try using a different browser, IE11, Edge or Firefox?
- sciminiApr 13, 2021Guide
I will try to power down and back up.
Tried three different browsers and all have the same results across different devices, same results
Can't recall fw since can't see the page. I believe it upgraded to the latest when I set it up Sunday.
Also worth noting, the app doesn;t detect the orbi either.
- FURRYe38Apr 13, 2021Guru - Experienced User
