Mitch_R
Jun 09, 2021Guide
Checking for firmware updates RBK753S
I have an AX4200 (RBK753S) system. I believe the firmware is up to date, so I'm not worried about that. My concern, though is that I get an error message when I just try to check for an update. Whe...
Mitch_R
Jun 10, 2021Guide
Thanks. I have a Netgear CM1100 modem.
The firmware updated fine when I set up the orbi system, and I can always check manually for an update. I just didn't know why the app and the router ip address both gave error messages.
Jun 10, 2021Guru - Experienced User
Ya, just sometimes is a NG service issue. I did check mine last nite, didn't get a service error. So not sure why your seeing this. Anything is possilbe when it comes to Orbi.
Has a factory reset and setup from scratch been performed since last update?
- Mitch_RJun 10, 2021GuideI haven't done a factory reset. I just bought these units a month ago, and I think it installed an update during setup.
- FURRYe38Jun 10, 2021Guru - Experienced User
You can save off a back up configuration to file, factory reset, check for FW update status on the RBRs web page and see if it still gives an error.
Re-load the saved config after checking.
