lw187
Dec 05, 2020Guide
Chromebook Connection Issues - DNS Problem?
Have had multiple chromebooks lose connection to internet. Is this related to the dns issues? Other devices fine
Dec 05, 2020Guru - Experienced User
Try it. You can always revert back...
Another test to try, just a quick on, disable WPA security on the RBR. Connect the Books to the open signal. Check operation. Re-enable WPA2 and AES after testing.
Are the Books WPA3 supporting at all?
lw187
Dec 05, 2020Guide
Ty for those tips will circle back
- lw187Dec 05, 2020GuideDo you have a personal opinion? 64 vs 2347?
- FURRYe38Dec 05, 2020Guru - Experienced User
Settings these is for trouble shooting only.
I've been using 64 as a default test measure for NEST controller operation. NG I presume feels that 64 should work for most every device connected. So I'm trying to test mine using default settings. I have tried 2347 before and so no real differences.
