LameGoose
Dec 05, 2019Tutor
Chromebooks refuse to join Orbi WiFi 6 network (AX6000)
I just configured my new WiFi 6 Orbi AX6000 (RBR850 + RBS850), and my Lenovo C330 units (x2) fail to join the network. All of my other devices connect and perform without issue (mostly Apple device...
- Apr 07, 2020
We have a fix! My Chromebooks are finally connected.
1. Login to orbilogin.net.
2. Click ADVANCED Tab, on a far left panel click on ADVANCED option and then select Advanced Wireless Settings under it.
3. Change the CTS/RTS value to 2347 then click APPLY button to save the settings.
4. Then, try again connecting your Chromebook to the wifi network.Note: After I did this it did not work right away. I forgot the network on the Chromebook and restarted the computer than tried to connect and bam I'm connected to the Orbi. Keep you posted if I have any drops but working as of now.
freeridevt
Dec 14, 2019Initiate
We are having similar issues with an Orbi Router/Satelite combo. Everything else works fine (various laptops, cell phones, printers,etc.) but ever since we added the new Orbi devices our Asus Chromebook C202S can't connect to the Sateliete. Its an Orbi RBS50v2 (brand new).
If I set the laptop next to the Orbi Router, it works fine. It specifically won't work when connecting to the Satalite. The connection is never established - it just continues to try to establish a connection to the wifi SSID. I've seen it partially get connected and then it ends up with the wrong IP configured as the router. Pretty disappointing.
Chuck_M
Dec 15, 2019Mentor
Have you tried to factory reset Just the Satellite (since that appears to be were the issues lay)
- freeridevtDec 16, 2019Initiate
Tried a factory reboot but the problem continues.
- FURRYe38Dec 16, 2019Guru - Experienced User
I would make contact with Google about this. Also check in with NG support. File a support ticket.
