LameGoose
Dec 05, 2019Tutor
Chromebooks refuse to join Orbi WiFi 6 network (AX6000)
I just configured my new WiFi 6 Orbi AX6000 (RBR850 + RBS850), and my Lenovo C330 units (x2) fail to join the network. All of my other devices connect and perform without issue (mostly Apple device...
- Apr 07, 2020
We have a fix! My Chromebooks are finally connected.
1. Login to orbilogin.net.
2. Click ADVANCED Tab, on a far left panel click on ADVANCED option and then select Advanced Wireless Settings under it.
3. Change the CTS/RTS value to 2347 then click APPLY button to save the settings.
4. Then, try again connecting your Chromebook to the wifi network.Note: After I did this it did not work right away. I forgot the network on the Chromebook and restarted the computer than tried to connect and bam I'm connected to the Orbi. Keep you posted if I have any drops but working as of now.
fangruoyuan
Mar 10, 2020Guide
Hello, please check your wifi is in secured mode(wpa wpa2) if it is in open mode, i think the chromebook will refuse to connect. I have the unsecured satellite wifi issues for my rbk852.
- EroachMar 10, 2020GuideYeah I tried everything. Turning off security. Also tried WEP, WPA2, and WPA3. Also tried turning AX mode off.
- FURRYe38Mar 10, 2020Guru - Experienced User
Did you try and disable AX mode while leaving the wifi security open?
Seems like a problem with the Chrome book and NG FW if the chrome book won't even connect with security turned off.
I would open a support tickect with NG and Google and see if something can be done. The wifi drivers between the Chrome book and Orbi AX needs to made compatible.
Eroach wrote:
Yeah I tried everything. Turning off security. Also tried WEP, WPA2, and WPA3. Also tried turning AX mode off.- RobsritMar 12, 2020Aspirant
Have you solved this? I have the exact same issues at my house. I took a Netgear Nighthawk offline and replaced with the Orbi WiFi 6.
Since then the Chromebook will not attach. With the recent work/school from home initiative I need these online. Any update would be apreciated.
