LameGoose
Dec 05, 2019Tutor
Chromebooks refuse to join Orbi WiFi 6 network (AX6000)
I just configured my new WiFi 6 Orbi AX6000 (RBR850 + RBS850), and my Lenovo C330 units (x2) fail to join the network. All of my other devices connect and perform without issue (mostly Apple device...
- Apr 07, 2020
We have a fix! My Chromebooks are finally connected.
1. Login to orbilogin.net.
2. Click ADVANCED Tab, on a far left panel click on ADVANCED option and then select Advanced Wireless Settings under it.
3. Change the CTS/RTS value to 2347 then click APPLY button to save the settings.
4. Then, try again connecting your Chromebook to the wifi network.Note: After I did this it did not work right away. I forgot the network on the Chromebook and restarted the computer than tried to connect and bam I'm connected to the Orbi. Keep you posted if I have any drops but working as of now.
Eroach
Apr 07, 2020Guide
- FURRYe38Apr 07, 2020Guru - Experienced User
Awesome fix. Glad that worked. Thanks for sharing this information. Hopefully it will help others.
Eroach wrote:We have a fix! My Chromebooks are finally connected.
- roughwaterjdApr 08, 2020Initiate
This change worked for me (so far). Thanks for the tip!
- DruizerApr 19, 2020Initiate
BINGO! Very easy fix. I was about to hook up my old orbi RBR40 just for the Chromebooks.
- DSummer68Apr 25, 2020InitiateThis worked great, thank you for letting us know what the fix was. YOU ROCK!
