Getnoldfast
Mar 18, 2022Aspirant
CLIENTS STOP CONNECTING AT 6PM EACH NIGHT
MODEL: RBRE960 (AXE11000) Hello! I have an odd situation with my new ORBI RBRE960 system. I have 3 SSID's...HOME, GUEST, GATE. The GATE Wi-Fi is being beamed to a gate where a wireless keypad...
- Mar 19, 2022
Hey TC,
Thanks for writing. I was able to get it figured out. Turned out to be an inline coupler that might be the problem. I tested the two legs of ethernet cable using a cable tester and initially, wires 1 and 2 didn't appear to be connected, with wires 3-8 working as expected. I swapped out the coupler and it all came back up and online. I hate it when I make assumptions about stuff like this thinking it "should" be working. Once again, lesson learned.
Because I assumed that the physical portion of this setup was OK, I focused on the software and other aspects of the setup. Boy is my face red 🙂
Thanks again for your time and help and have a good weekend!
Getnoldfast
Mar 19, 2022Aspirant
Thanks for taking the time to help SuperViral, appreciate it!
Mar 19, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
