hgs71's avatar
hgs71
CM1000 and RBK753
Question 1:  Is the CM1000 a good match for the RBK753 package?   Question 2:  With the RBK753 package, is it possible to run one satelite via ethernet and the other via  WiFi?   Thank you.
  • plemans's avatar
    Sep 15, 2020
    hgs71 wrote:
    Question 1:  Is the CM1000 a good match for the RBK753 package?---if its supported by your ISP, then sure. If supported by your isp, it should be good up to gigabit speeds.
    WiFi?----yes
    Thank you.
