hgs71
Sep 14, 2020Aspirant
CM1000 and RBK753
Question 1: Is the CM1000 a good match for the RBK753 package? Question 2: With the RBK753 package, is it possible to run one satelite via ethernet and the other via WiFi? Thank you.
- Sep 15, 2020
hgs71 wrote:Question 1: Is the CM1000 a good match for the RBK753 package?---if its supported by your ISP, then sure. If supported by your isp, it should be good up to gigabit speeds.
WiFi?----yes
Thank you.
Sep 15, 2020Guru - Experienced User
WiFi?----yes
Thank you.
hgs71
Sep 15, 2020Aspirant
Thank you.
