cbassins
Aug 26, 2020Aspirant
CM1150v + Orbi RBK752 - Wifi and Wired Connection Issues
Hi, I just purchased a Netgear CM1150V cable/telephone modem along with an Orbi RBK752 Mesh system for my Xfinity service. I had Comcast activate the modem. I was able to get an internet con...
cbassins
I did connect my Orbi router directly to my laptop (with the WiFi adapter disabled) and verified that the connection works.
I don't know if I can directly connect a satellite to the Orbi router outside of just test purposes, since the location of where I'd like to have the satellite is on a different floor/area of the house. The ethernet connection is wired to the switch that I referenced before.
Mstrbig
Aug 26, 2020Master
cbassins wrote:I did connect my Orbi router directly to my laptop (with the WiFi adapter disabled) and verified that the connection works.
You can move the satellite to the same floor for testing purposes.
How far is the satellite, on the second floor, from the router? Sometimes you have to move the satellite to a more desirable location, which may not be your most desirable.
- cbassinsAug 26, 2020Aspirant
I measured the length of the room on the 2nd floor. I would say it's somewhere between 20-35ft in total.
It's in the same location in my family room where I currently have my EnGenius WiFi extender (which has worked fine with my old Comcast modem/router/switch setup.
