ssohata
Jun 30, 2020Aspirant
CM1200 and Orbi Mesh?
I am looking to upgrade modem to docsis 3.1 and WiFi system. Cable internet provider is Spectrum Hawaii. I'm looking at a CM1200. Is this compatible with Orbi mesh system? Website just says CM1200 compatible WiFi6. Thanks in advance.
- Yes, virtually any modem is compatible with any router. WiFi 6 is just another form of the router sending out WiFi, you will need a WiFi 6 compatible device to take advantage of the increased speeds.
- KMDonlonVirtuosoYes, virtually any modem is compatible with any router. WiFi 6 is just another form of the router sending out WiFi, you will need a WiFi 6 compatible device to take advantage of the increased speeds.
First make sure your ISP supports the model model your looking for.
