donawalt's avatar
donawalt
Hero - Experienced User
Aug 28, 2020
CM2000 and Orbi 850
HI all, I noticed the Netgear CM2000 is now out. https://www.netgear.com/home/products/networking/cable-modems-routers/cm2000.aspx   For those on the Orbi 850 system with a CM1200, this won't buy ...
  • plemans's avatar
    Aug 29, 2020
    Both the RBR850 and the CM2000 have a 2.5g port.
    It tends to work better, more stable than wan port aggregation.
    I've had better speeds stability off my CAX80 using the 2.5g port than using port aggregation on any of my other setups.
