fat_dog23
Aug 13, 2020Aspirant
Combination of AP mode and satellites results in massive security issue
Hello, I have a problem with my NETGEAR Orbi RBK853 (1 router, 2satellites) in AP mode in combination with a Fritz!box. The Fritzbox takes care of the DECT telephone and the Internet, directly behind...
Aug 13, 2020Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
Do the RBS report same no security if wirelessly connected?
Can you configure the modems DMZ for the RBR and change the RBR to router mode and see if the RBS still report same problem?
