Staceymorrison
Jun 10, 2023Aspirant
Combining Orbi systems
Hello, I have an RBR750 router and RBS750 satellite. I want to send the internet down to a granny flat. I ask the person in the granny flat to get a set of satellites for this system but they co...
Jun 11, 2023Guru - Experienced User
do you have ethernet ran to the granny flat?
You could always connect the 2nd system to the first with the 2nd in access point mode.
Here's the orbi compatibility chart.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Jun 12, 2023Guru - Experienced User
How far is the distance from home to granny flat?
