ellab
Dec 19, 2023Follower
Compared to Google Mesh
I have installed the Google mesh in a 3 level house using 6 wireless and Ethernet backhaul nodes; and also a 1200sf apartment using 2 nodes.
I’ve been asked to upgrade the mesh system. Would you recommend the Orbi?
The main complain of the Google mesh is the WiFi would stop working for 5 to 10 mins suddenly at odd times. So, the person would be on a Zoom call, and then disconnected and unable to reconnect later. Weird part is the other nodes work, so she’ll have to walk close to the other node.
It seems it’s doing an upgrade or self test. I’ve no control over it.
30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰https://www.netgear.com/hub/wifi/mesh/orbi-satellites/
For that size of home, router and just one RBS would be needed.
