MartinaKi
Dec 14, 2023Initiate
Compatibility of Orbi CBR750 with Orbi RBK852
My ips recommend I update my modem to achieve 5-10 times higher upload speeds with my current plan. One of the modems they recommend/is certified for use is the Orbi CBR750. I currently have a Motorol...
MartinaKi
I currently have a Motorola MB8611 docsis 3.1 modem. My ISP is Xfinity and they are telling me this modem is not capable to give me the higher upload speed. They recommended several modems, the one I already mentioned, and a NETGEAR CM3000 being two of them. I couldn’t find a NETGEAR CM3000 anywhere, so I don’t know what’s going on with that. They also named 2 routers from Hilton Electronics, but I thought since I have the NETGEAR mesh system, a NETGEAR modem would be the better choice.
Dec 14, 2023Guru - Experienced User
Yes the MB8611 can only do about 1Gb.
No idea when the CM3000 will be launched. Could be a ISP only modem as well.
I know the CM2000 and CM2050v are supporting of ISP speeds over 1Gb since they have 2.5Gb WAN ports.
