w1lluser1
Apr 29, 2020Aspirant
Compatibility of RBK853 wifi 6 system with RBS20 satellite
Hi there, Is it possible to use an RBS20 satellite with the RBK853 wifi 6 system? I could either wire the RBS20 satellite to the RBR853 router or have it wireless, however I do not want to disable A...
Apr 29, 2020Guru - Experienced User
You could wired the RBS to the RBR. Currently RBS AC series units are not wirelessly compatible with Orbi AX.
- w1lluser1Apr 29, 2020Aspirant
Hi Furrye38,
Thanks for the response. Can I just confirm that I would not need to disable AX mode for the RBK850 system, it will only be the RBS20 satellite that will use AC technology?
Cheers!
- FURRYe38Apr 29, 2020Guru - Experienced User
You can leave AX mode enabled. The RBS20 will be acting like a wired AP is all.
Thanks again for the response.
Just to be sure I've understood, if I add an RBS20 satellite with a wired connection to the RBR853, the AC satellite will join the mesh network alongside the RBS850 satellites, the only difference will be that it's not capable of AX connections?
Cheers!
