MooseW31
May 23, 2021Follower
Compatibility Question
Please disregard the model listed. It wouldn't take either of mine in so I put RBS40 in so I could post this. I have an Orbi CBR750 cable modem/router. Will an RBS20 satelitte work with that? I have...
May 23, 2021Guru - Experienced User
Be sure to visit the Orbi with Cable modem forum:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
You can ethernet connect the RBS to the CBR is all.
MooseW31 wrote:Please disregard the model listed. It wouldn't take either of mine in so I put RBS40 in so I could post this.
I have an Orbi CBR750 cable modem/router. Will an RBS20 satelitte work with that? I have an RBS20 that I can't get to sync no matter what I try.
Thanks in advance!
