Gianfi
Jul 24, 2021Follower
compatibility RBK352 e RBK752
I am buying a RBK752. Is it compatible with RBK352? thank you
Jul 27, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
I don't believe they are since the 3 series is only dual band while the 7 and 9 series are Tri band systems.
Thank you.
