classicrokr
Mar 21, 2020Follower
Compatibility RBK852 Orbi WiFi 6
Hi,
1. Is the Nighthawk CM1000 Modem compatible with the RBK 852 Orbi WiFii 6 router system?
2. With the Orbi WiFi 6 - I know my wifi 5 devices will connect. Will they benefit at all from the wifi 6 standard - such as improved latency, faster speeds to device? (I only have 2 devices with wifi 6 built in)
Thanks
classicrokr wrote:......
No, Wifi AC devices will connect using Wifi AC (IEEE 802.11ac) and Orbi AX will not make any noticible improvement for those devices.
On the other hand, Orbi AX has a more powerful processor and it's faster than Orbi AC. You will clearly notice this when managing the system using the Orbi app or the web GUI.
- KMDonlonVirtuosoYes, your modem is compatible.
As far as WiFi benefits, a WiFi 6 capable device will certainly benefit from the ax wireless connection. My laptop has a WiFi 6 capable network card and connects at over 900mbps. - FURRYe38Guru - Experienced User
ALL CM modes are compatible with both Orbi AX and AC.
- ekhalilMaster
