RMarble57
Sep 19, 2022Aspirant
Compatibility RBS50Yv2 with RBS750 Router
I'm being told that the RBS50Yv2 Outdoor Satellite isn't compatible with my existing RBS750 Router and Satellites. It says right on Netgear website that it works with existing Wi-Fi and on the box w...
RMarble57
Sep 20, 2022Aspirant
I do not wish to have a separate wifi name for the outdoor area.
As I understand that putting it into extender mode would require that I have 2 different wifi names on the property and that is not acceptable
Sep 20, 2022Guru - Experienced User
I believe when in extender mode you can set it to use same SSID name as the host SSID. I get same options on my EX extenders so I presume this would be the same on the RBSY.
