RaCr1972
Aug 07, 2023Aspirant
Compatibility RBS760
I will expand my netwerk to the garden with an extra satelite. I already have a RBK753 system (1 router, 2 satelites). Unfortunatelly the RBS750 satelite is not available anymore. Is the newer triban...
- Aug 07, 2023
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Also EX and EAX series extenders and work as well. Just won't integrate like the RBS do.
Aug 07, 2023Guru - Experienced User
RaCr1972
Thank you. This is a clear overview I can use to find a compatible satelite.
