klj5060
Sep 11, 2023Aspirant
Computer not showing up
Having the same issue. Seems like other devices are showing up - but the actual Dell computer is showing as offline all the time.
Sep 11, 2023Guru - Experienced User
There a product model your referring to here?
klj5060
Sep 12, 2023Aspirant
The Orbi 750 mesh system
- FURRYe38Sep 12, 2023Guru - Experienced User
The RBK750 or CBK750 series?
- klj5060Sep 12, 2023Aspirant
Think it's the RBK version, but honestly not 100%
Please look at the main router base unit. If the back of the unit you see a ISP Cable coax line connected. It's the CBR version.
Confirm this by looking at the data sticker on the bottom.What Firmware version is currently loaded?
It's the RBK version - and the firmware is v4.6.14.3
