Kdepot
Feb 04, 2022Aspirant
Configuring Orbi 753 for Open VPN
I found this post which exactly explains my problem,"The smartphone OpenVPN setup zip file generated by the Netgear system creates 4 files. There is no way to open these files directly in the iPhone...
CrimpOn
Feb 04, 2022Guru - Experienced User
It might be worth going through the procedure again. On my original (ancient) Orbi, the smartphone process creates a zip file containing only one file "smart_phone.ovpn". The Windows process creates a zip file containing four files, and the non-Windows process creates a zip file containing five files.
I am thus 99% certain that the post being referenced is incorrect. (Not having a 750, I cannot go through the steps myself. Netgear has been including OpenVPN in their WiFi router products for years. Seems a stretch that after all this time, this would have changed.)
Kdepot
Thanks for the replies. I’m trying this on an iOS platform and I’ve tried to get the files to open with the Open VPN app and it’s a no go.
- CrimpOnFeb 04, 2022Guru - Experienced User
Kdepot wrote:
get the files to open with the Open VPN app and it’s a no go.According to OpenVPN, the iOS app wants one file with an extension ovpn.
The discussion is in terms of creating files on MacOS and transferring them to iOS, but the central theme is "one file named *.ovpn".
I sincerely think it would be worth a few minutes to go back and generate the 'smartphone' configuration file again.
- KdepotFeb 04, 2022Aspirant
I have tried multiple times downloading the file client.ovpn, transfering to my iPad and opening with the OpenVPN app and every time it just says, fails to parse profile: ca.crt, client.crt, client.key
I don't understand the discussion on combining the files into one. When I open them with a text editor, the formats don't quite match the example on the page you suggested and I'm not knowledgeable enough to figure out how to cominne the file, although I did try unsuccessfully.
Perhaps we are describing different files. On my Orbi, on the web interface, advanced tab, advanced settings menu, I select VPN Service and get a page that looks like this:
I click on the button "For Smart Phone", which causes the Orbi to download a file to my PC titled smart_phone.zip. Inside that file is one text file called smart_phone.ovpn. I extract that ovpn file and transfer it to my smart phone (or tablet). I never get anything called "client.ovpn".
If this is the method you are using to get the ovpn file, then Netgear must have changed something.
