Kdepot
Feb 04, 2022Aspirant
Configuring Orbi 753 for Open VPN
I found this post which exactly explains my problem,"The smartphone OpenVPN setup zip file generated by the Netgear system creates 4 files. There is no way to open these files directly in the iPhone...
Feb 06, 2022Guru - Experienced User
Is this in any online KB CrimpOn ? If not, maybe we can get NG to put something up if this truely works.
CrimpOn wrote:
You are entirely correct. Netgear changed the contents of the smart_phone.zip file. I asked another user who has an Orbi 750 to enable OpenVPN on his Orbi. He did so and created this pdf explainiing how it went:
It is truly a humbling experience thinking "I know all about that", only to find that I do not.
Can you please duplicate his experience and see if it works on your Orbi?
CrimpOn
There is SO MUCH that is not on line. I expect Netgear thinks people will follow the directions for whichever product they happen to be running.
- FURRYe38Feb 06, 2022Guru - Experienced User
Ok. Lets check this out. If it works as expected, will request NG to put this up.
