Kdepot
Feb 04, 2022Aspirant
Configuring Orbi 753 for Open VPN
I found this post which exactly explains my problem,"The smartphone OpenVPN setup zip file generated by the Netgear system creates 4 files. There is no way to open these files directly in the iPhone...
CrimpOn
Feb 06, 2022Guru - Experienced User
There is SO MUCH that is not on line. I expect Netgear thinks people will follow the directions for whichever product they happen to be running.
Ok. Lets check this out. If it works as expected, will request NG to put this up.
