Larry333
May 25, 2022Aspirant
Configuring RBKE963 with Verizon Fios G3100 Router
I am considering buying the Orbi 6e router with 2 satellites. How would I set this up to retain functionality with my current Verizon Fios services (Internet, Phone, TV)? Thank you.
ttps://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios
For ISP modems and ONTs with built in routers, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-ModeI would start with option#2 first.
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
