JoseLopez
Jun 07, 2023Guide
Configuring the Orbi RBK752 kit with an at&t Fiber BGW320-500 Gateway
Hello everyone, My name is José. I am a new member. I am seeking advise from anyone here that can help me with the setup and configuration of an Orbi RBK752 system with an AT&T Fiber Modem/Router ...
- Jun 18, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jun 08, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Not all modems are bridgable.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
JoseLopez
Jun 08, 2023Guide
Thank you!
