JoseLopez
Jun 07, 2023Guide
Configuring the Orbi RBK752 kit with an at&t Fiber BGW320-500 Gateway
Hello everyone, My name is José. I am a new member. I am seeking advise from anyone here that can help me with the setup and configuration of an Orbi RBK752 system with an AT&T Fiber Modem/Router ...
- Jun 18, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
BillHuntKS
Sep 18, 2024Aspirant
one more quick question... under the final config were you still able to use the Guest Network?
Thanks in advance.
- JoseLopezSep 18, 2024Guide
Hello BillHuntKS,
Yes, I was able to create a Guest Wi-Wi network with it’s individual name and password, and it works fine.
