JoseLopez
Jun 07, 2023Guide
Configuring the Orbi RBK752 kit with an at&t Fiber BGW320-500 Gateway
Hello everyone, My name is José. I am a new member. I am seeking advise from anyone here that can help me with the setup and configuration of an Orbi RBK752 system with an AT&T Fiber Modem/Router ...
- Jun 18, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
BillHuntKS
Sep 18, 2024Aspirant
one more quick question... under the final config were you still able to use the Guest Network?
Thanks in advance.
JoseLopez
Sep 18, 2024Guide
Hello BillHuntKS,
Yes, I was able to create a Guest Wi-Wi network with it’s individual name and password, and it works fine.
